10 ways 3Shape Dental System™ 2015 just made CAD/CAM technology so much better
To drive your dental lab’s business and cost efficiency, you need a CAD/CAM solution that is fast, accurate and easy to use. 3Shape Dental System™ 2015 helps you provide the best services at the best possible prices. The widest range of indications and libraries. Integrated, clear and intuitive workflows. Award-winning desktop scanners. An ecosystem that lets you combine what you use today with what you may need tomorrow.
Check out these 10 new ways the industry’s #1 CAD/CAM solution just made your digital workflow so much better:
Next-generation full denture design
Denture design software includes Model Analysis and Smile Selector for selecting and adapting the optimal denture teeth library. Three full denture prosthesis manufacturing options: Glued-in teeth, injection molding, and basal reduction with automatic undercut removal and teeth pockets drill compensation.
Print and mill positioning guides for Abutment placement
Design, mill and print positioning guides for the placement of abutments, temporaries and veneers.
Easy design of Table Tops and non-prepared Veneers
New workflow makes it extra fast and easy to design onlay-style restorations on top of non-prepared teeth by placing the anatomy first.
Split bridges with male and female connector
Choose where to split the bridge using a male and female connector with two separate definable insertion directions.
Change order form during design without losing existing work
Change the order form, materials and switch from a one-layer crown to a two-layer crown during the design process – even in the middle without losing your original design.
Signature libraries by recognized masters
Esthetic and functional morphology design libraries created by Jochen Peters (Germany), Nondas Vlachopoulos (Greece), Lee Culp (USA), Matt Roberts (USA) and others, at your fingertips.
Smile Composer™ 2.0 with integrated Sculpt Toolkit
Choose from a full range of tools previously split between Smile Composer™ and the Sculpt Toolkit – and use them now in any order you like.
New scanning application
Faster scanning through more efficient post-processing in the background. New user interface lets you choose the order of your scans.
Upgraded D750 and D850 lab scanners
Lab scanner line upgraded and two new models added. Benchtop scanners feature improved accuracy and increased scanning speeds of 30%. Upgraded D750 and D850 lab scanners with extended interior and Blue LED scanning. Both models feature a die scanning time of 25 sec. and full arch 55 sec. D850 has 7 μm (ISO), 8 μm (Implant bar) accuracy.
Upgraded D-series lab scanners, 2 new models – D2000 and D1000
Upgraded lab scanners and two new models featuring improved accuracy and increased scanning speeds of 30%. New D2000 and D1000 feature “all-in-one” scanning to reduce handling time by up to 40%. D2000 simultaneously scans two models at once.
