Dental System software interface displayed
Implant Studio — Software updates
3Shape Implant Studio 2026.1
3Shape Implant Studio 2026.1  creates more options for you to design advanced implant cases. The software now supports multi-unit abutment planning, and we have streamlined the screw-retained crown design process into a smooth, iterative one-step workflow for faster, more intuitive planning.  Download it here.
NEW Multi-unit abutment planning (MUA)
With Implant Studio 2026.1’s enhanced integration with 3Shape Dental System, labs and clinicians can now design restorative components directly in Dental System based on their implant and MUA planning done in Implant Studio. The smooth integration eliminates data transfer errors and ensures a fully digital workflow.
  • Streamlined Full-Arch Planning
    Workflows for treatments like All-on-4 and All-on-6 have been simplified with intuitive tools designed specifically for full-arch restorations.
  • Enhanced Implant Parallelism
    Easily align implant or restorative axes for optimal outcomes and prosthetic fit.
How MUA planning works
0
you select & place MUA
Choose the desired MUA type from the library and place it during implant planning.
0
adjust for Parallelism
Fine-tune the angle to achieve optimal restorative alignment.
0
export to Dental System
Send the finalized plan to the Dental System for designing.
NEW Improved workflow for screw-retained crowns
Now you can design screw-retained crowns in a single, seamless iterative step—eliminating the need for time-consuming “copy and remove approval” workarounds. The optimized workflow simplifies complexity and saves you valuable time.
Important notes
Patches
 Release Date  Comments
Implant Studio 2026.1 December 2025 Full release
Useful links
Implant Studio on 3Shape Learning & Support
PREVIOUS UPDATES
KEEP LEARNING WITH 3Shape Learning & Support
Library of tutorials:
  • 3Shape Implant Studio Fundamentals: Implant studio is an open flexible system, which means you can choose to plan your implant positions, design your surgical guides before producing them or you can choose to only perform one of those steps. In this section we will show you the whole workflow and you can choose which parts to do yourself.
  • Setup and administration: Learn about some basic steps that should be taken to in order to work with the software.
  • Treatments: From single implants to full edentulous rehabilitations, Implant Studio enables you to plan and design a wide range of treatments, in-house, by collaborating with a laboratory, or using a Design service.
NEW 3Shape Produce
Implant Studio 2024 works with 3Shape Produce, easing the process of producing surgical guides and screw-retained crowns
The machine choice from the software is transferred to the Produce step, that allow for seamless integration and optimized production on a wide range of milling machines and printers!
Learn more.
ASIGA
Formlabs
Rapid Shape
Ivoclar
VHF
DGShape
SprintRay
Dental System updates
TRIOS Design Studio updates
Improvements and changes in the TRIOS Design Studio software.
Model Maker updates
Ortho System updates
ⓘ Contact us or ask your reseller regarding availability of 3Shape products in your region.
